2.0 Engine problem(Primera)
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
chosakwe
Car: Nissan Primera
I bought a used 1997 Primera and have not had peace, the engine is always giving me problems, Its twincam and the valves are always developing problems. Its always jumping timing. Whats should I do?
chosakwe
Car: Nissan Primera
I have a problem with my primera
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'm going to move this to the FWD SR forum where it'll get better responses.
nametakennow
Car: '06 MINI Cooper S
Valves don't magically develop problems. Do you rev it out a lot? Have you tried resetting the timing with a timing light?
Chris859
When you say jumping time - Are you refering to cam timing? If so you need to make sure your timing chain tensioner, and chain guides are in proper working order. If ignition timing won't stay set(assuming you are setting it correctly) - You need to proceed to testing sensors that can influence timing such as temperature, and tps sensors for starters.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
