Peabody wrote:So from the 1st reply it seems like the clutch should be pretty soft if everything is working properly. How can I check the clutch booster? Please don't say replace it and if it gets softer then it was bad.
THANKS
Yes, the Z32 clutch action IMO is VERY soft.
I've never heard of a clutch booster and as far as I know there is no such thing for the Z32, although I can only say this from knowledge of my own TT and 5-speed swapped NA which both have a "normal" clutch system: pedal, master cylinder supplying/pushing fluid to the lines through two bleed points to a slave cylinder, which pushes the clutch fork actuator described in the link I sent, which moves the clutch.
Where would a "clutch booster" be involved in this system?
Do you have pics, or a page in the FSM detailing this?
