jmorasch »
https://forums.nicoclub.com/jmorasch-u70840.html
Sat Feb 14, 2009 8:24 pm
Id posted about the compression being low in cylinder #7 the tech told me that I had 65lbs in 7.the car had run great until at a stop sign one day it started the shudders.Id run some heat and injecter cleaner thru the tank and it seemed to have cured things but soon returned worse than before. well I finally got motivated and took the Q to the shop and ohmed the injectors.#7 was a dead injector. so after work mon. the injector was in and me and a friend of mine (hed changed 3 injectors in his Q already)started. Thanks to all the previous post and guides from everyone here on how to's,from ohming the injectors,to what to lube the O rings with. took us 8 hours to complete the job but its running great again.Id of never attempted this without Everyone here at NICO. I know that injectors are know to fail in pairs,so Im planning on the next replacement job now. saddest of all though,friend of mine that helped me,hed replaced the 02 sensors,3 injectors and done allot of basics,like cleaning his MAF sensor.told him about NICO after I met him.hes done alot of research here....had his Q running real good....well it was really cold here in K.C..he lives in a apt.complex with supposable security patrols.left his Q running and went back in.came out locked his door turned to go to work and watched two guys driving off really fast in his car.Im sick for him now that would really SUCK!!!!!!!!!
