vq35de »
https://forums.nicoclub.com/vq35de-u7384.html
Fri Dec 19, 2003 5:05 am
ok, for dyno info.........make sure you have a wideband O2 sensor available. The ones that go in the end of the tailpipe are fine.
reset your ECU 12-24 hours before and drive hard on the way to the Dyno and the night before.
Check your airfilter for dirt, bugs, etc that may be blocking air. A K&N or other oiled type can look brand new on one side but completey black on the other, same with paper and foam filters.
Try to get at least one fillup in between now and the dyno.
Smoothing, doesn't really matter, play with the run view software and set the smoothing to your taste.
Dynojet 248 is very common, pretty much any dyno will work as long as it is not a Mustang Dyno.
5th gear is the best but some dyno's are only rated at 120 mph max, so in that case a 4th gear pull will work and oly be off <5hp.
stock wheels hmmmm........ if you have a different size wheel on or a steel wheel on with your winter tires then yes, but if the wheels are same size just different look, no you will be fine
top speed in 5th will be around 135 or 140 or so.
that 90 mph rating is "sustained" speed on perfect road conditions. I think if it is your first time on a dyno, it might be cool to see the difference between your snow tires and stock tires/wheels. anyways I probably wouldnt go above 120 or so in the snows. But that long should be ok for a few seconds.
