Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Mon May 09, 2005 4:51 pm
Application: R32 RB26 into 1995 S14
Everything has gone pretty smooth so far. I am just finishing up the intercooler piping and the gauges.
Everything ignition wise has worked fine since day one. McKinney did the wiring, so yeah. My radio has always worked, windows work, motor would turn when the starter was engaged, etc.
So today, I bought a 12 foot 4-an stainless steel braided line to run from the oil pressure port on the RB26 to the oil pressure gauge inside the car. I had previously run that stupid arse little nylon line to the gauge, but I was not comfortable with those stupid little compression fittings one bit.
So, I removed the nylon line and fed the new 4-an s/s braided line in through the firewall grommet on the driver's side of the car in behind the front fender, which is exactly where the other line had been going previously.
I finished everything up, and now I have a HUGE problem. When I turn the ignition to run, I have no power windows, no radio, no A/C blower, nothing. And when I turn the ignition all the way to engage the starter, it does nothing. All I have are lights and poor door locks. I checked all the fuses on the interior fuse block. And I did the same for the fuse block in the engine bay. I didn't find a single burnt fuse.
Looking closer at the interior fuse block, I found a grey plug in behind the fuse block that was disconnected, is has about 4-5 green wires and 1 black wire. What is this plug for? If I remember correctly, I have seen this plug before in the past, and it has always been unplugged. Anyone have any insight into this?
Tomorrow, I am going to test to see if the fuse block itself has any power to it. I do know that all the ignition wires were intact, and the ignition module itself does not feel broken or different than usual.
Thanks guys.
Modified by Ramius83 at 4:03 AM 5/10/2005
