you sir should shut your noob A$$ face and step away from the key board and watch what comes out of that smart A$$ mouth of yours! and if you red he only got the wide band wire caught cuz it was to close to the drive shaft. not his WHOLE WIRING HARNESS!!!! now to the problem, im almost positive the KA seal with in fact fit your SR transmission. cant hurt to try. and as for your turbo glowing. were you boosting it alot on the high way? how long were you driving?shift_SRDETuser wrote:Looks like it might be time for you to sell your car!!!!
Anytime you have engine harness wires from your car running close enough to your driveshaft to do something like you are saying it did makes any sensible person wonder why you would even try to work on your car by yourself.
To answer your question about the turbo well guess what--- it is running off the exhaust and as such can get glowing hot from the exhaust gases being pushed through there-- You are boosting your engine to 20lbs which is 1.5 bar and I would expect it to glow like that. It is possible that the wires you pulled out might have had an effect on the air flow and could have gotten it to dangerous levels if you have a rom tune then it should be ok--
yeah good thing you edited that whole bull$hit honda commentshift_SRDETuser wrote:Looks like it might be time for you to sell your car!!!!
To answer your question about the turbo well guess what--- it is running off the exhaust and as such can get glowing hot from the exhaust gases being pushed through there-- You are boosting your engine to 20lbs which is 1.3 bar and I would expect it to glow like that. It is possible that the wires you pulled out might have had an effect on the air flow and could have gotten it to dangerous levels if you have a rom tune then it should be ok--
yeah the .64 will boost earlier that is for sure. If it gets hot were you are and I am assuming Kentucky then yeah the water injection system would work well (awesome on Stis). Hell I am thinking about doing it to my car and I am only pushing 260-300 horsepower. I kinda don't want to get into bigger injectors, larger turbos, and tuned ecus since I occasionally get 28-32 mpg..... I want and need my mpg....kentuckyslider wrote:If I have to replace it this is what I will be going with.......http://www.atpturbo.com/Mercha...e=GRT
With the .64 AR it hits full boost at about 4200rpm but is easily capable of maxing out my 72lbs injectors. The GT3071R with .86 AR on garret's site is rated up to 480hp and the GT3076R(WG) with the .64AR is rated at 550hp. I should be able to run this turbo conservatively and still push 450-500WHP on 93 with my new cams and intake. Not to mention the water/meth injection.
