Red-KAT »
https://forums.nicoclub.com/red-kat-u14022.html
Thu Aug 25, 2005 9:06 am
Problems I had with my car on E-Manage Blue.
1: Crappy idle 2: Bad idle A/F and could never make it right. 3: Throttle problems when engine is not warm. Tries to choke and die. 4: Stomp on gas and the engine was lazy. Due to the fact that it would always overcompensated the fuel. 5: When on the gas a little and push in clutch the car would try to die from being to rich. (Turbo still sucks in air for a sec) 6: The car just seemed to be lacking power.
My new E-Manage Ultimate. (With the same exact tune)
1: Idle is smooth. 2: Good idle A/F. When I change a number it does something! 3: No more issues with the car being cold in the morning. Does not try to die. 4: The gas peddle seems very crisp and responsive. I tap it and it wants to move. 5: When I push in the clutch from part throttle it no longer trys to die. 6: The car feels like it has more power at lower boost. (Prob due to the airflow meter not being screwd with)
All in all its about the best ~$500 I have spent on my car. And in one day brought me so much joy in driving my car.
Tonight I am going to Wire in my Water temp, Crank Angle, Cam Angle, Knock sensor, Speed Wire, And any other option this thing has.
Ohh I also already wired in my LM-1 A/F into the Ultimate so I am going to try out auto tune... Muhahaha!
After I get my Cam Angle and Crank Angle I will be able to see and set timing easy! This is going to be fun. Almost like a stand-alone.
