1st good thing to do to your ka24e?
240surfjunkie
Car: 1992 nissan 240sx coupe
i just recently bought a 92 240coupe and i love it and the engines stock minus cold air and im wondering what i should do next any ideas?
guillermoe
Car: '93 240SX Hatch, '04 206 Peugeot
Welcome to NICO.
First thing you would make is check everything in your car, fix any issue you find in it, start reading all the stickies in nico forums and the most important thing... buy a flame suit as soon as possible. You will learn the reason soon enough
240surfjunkie
thanks ya i wanna start learning cause its my 1st sporty car and i wanna have fun and learn with it
NateDogg
First off you have a KA24DE. 'D' stands for double overhead cam. First year for that was '91.
You could probably get a better response from the KA forums, rather than the KA-T. Most of us who post here have turbocharged the KA so I think the response will be obvious.
Honestly if I had to do it over again I would've saved the money I spent on intakes and ECUs and put it all towards getting a turbo kit faster. If you want to turbo in the future, make sure you buy things that will transfer over. Your intake will not, header wont. Pretty much anything else will work, however.
Read as much as you can and also check out northwest nissans.
boznuttz
Car: MS13
Make sure it runs solid first.
480sx
Car: 1996 Pearl White 240sx
If i were you i would do the basics first. Do an oil change, and a full tune up. Plugs, wires, distrib cap and rotor. Change your fuel filter.
Lift the car up in the air and check your CV boots for cracking or tears. Shake your tires down and see if there is any play in your steering.
After that, id take it to a carwash while we still have some decently warm weather and put a coat of wax on her.
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
BELTS HOSESSPARK PLUGSOIL/FILTERNEW FLUIDSCOMPUTER DIANOGICS(SPELLED WRONG ) AT ANY NISSAN DEALERSHIP
DALAZ_68
Car: 90' 240sx CA18det
dont forget transmission fluids and coolant flush
S13FX
Car: '69 l20b Dimeski :)
send it to Lake Villa, Illinois, and tell them it's for Mike
WDRacing
moved
BlueMellonPop
Car: 1993 240sx
do your belts, hoses, motor mounts, plugs, wires, cap, rotor, valve cover gaskets if there's a leak, and seals to get the car running right.
spindrift187
So you get the idea, refresh the motor before you start splurging on parts. The KA is a surprisingly fun motor even in stock form when its running at efficiency.
Most stock 240's I have driven are sluggish and its disregarded as just a crap motor, you should see peoples faces after a stupid little tune up and general maintenance.
Razi
Car: Moo
I would fix any leaks and problems and make sure it runs nice
