1st gen Rogue bulb info
texdivot
Car: 2010 Nissan Rogue SL FWD
Gotham Gray/Gray Leather
I want to replace factory interior lights with something "amber" to match instrument panel and radio display color. Can someone provide me with part numbers. Nissan claims the map lights are #3175 but those are bullet shaped and don't appear to work. It takes a "wedge" type connector. Thanks in advance for the replies.
philipa_240sx
Orijin did some checking awhile back and found the #194 wedge bulbs are a drop in replacement.
rolade01
Car: 2010 Nissan Rogue SL AWD Carbon Silver Black/Blue Cloth
If you are going to use LED, try searcing for any T10 bulb for the front map lights and 31mm DE3175 for the dome and cargo lights. I replaced all of my internal bulbs with blue LEDs to match my Car DVD button panel - they look great. Good luck.
roguesv2011
Car: 2011 Rogue SV 2WD
was wondering if any one had a list of interior light bulb list for a 2011 rogue I want to install LED lights for my dome light map lights rear cargo light and a high power LED light for my back up lights i know the bulbs are 3175 for interior lights and 921 for a back up light the real question is the size i see diffrent sizes from 31 to 43 mm which one will it be ???? thanks
:confused:
Leo2005
2011 NISSAN Rogue (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
2011 NISSAN Rogue (With halogen capsule headlamps)
Low beam headlamp
H11
(The rest of information applies to both halogen and xenon headlamps)
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
7440
Tail light/Stop light
7443
High mount stop light
LED
Fog/Driving light
H8
License plate
168
Back up light
921
Front sidemarker
1157A
Rear sidemarker
7443
Glove box
158
Map light
DE3175
Dome light
DE3175
Trunk/Cargo area
DE3175
*Info was taken from http://www.sylvania.com
webzila
Car: 2012 Nissan Rogue SV w/SL Package
Remote Start & Homelink Mirror
Just want to bump this thread in case anyone else is looking for this info (like I was) for 2012 Rogue
For whatever reason the manual doesn't specify the map lights bulb type.
As mentioned it is 194 (T10) - all of the following can be used as replacement: 194, 168, 2825
The dome light is 3175
Return to “Rogue Forum”
