Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Nov 08, 2003 8:21 pm
The stock air box [as measured in front of MAF after oem filter] has a restriction of around 5" Water Column at 6900 rpm [where the VE is around 70% [547 x 0.7= 382 CFM] ..........yet only 1.5" WC at 4,000 rpm wher VE = 90% or 285 CFM............around 4" at 6,000 rpm =360 CFM.
Measure the same parameters in front of the oem filter [test hole in bottom of air box and the 5" DROPS to 3.5" and the 4" at 6,000 rpms drops to 3.0" and the 1.5" drops to 1.25"
Somewhere around 6,300 rpm the valve lift/diameter and tuning falter and begin to stall the air flow [the curve reaches a peak and noses over].
The point I am making is there is essentially no restriction below 4,000 rpm in the air filtration, the MAF, the TB, the plenum, the runners or the valves............redesigning the system will at best not reduce power too much.
I guess if you had to have a mod, the best would be to leave the top of air box and filter in place to maintain the MAF calibration...the screen, the air horn in the top the oem air filter and it spacing from the horn etc.
Other than the hot engine compartment air you would ingest where even 11F hotter air [1% less dense] pretty much negates any gain from the slightly higher flow from lower restriction.
You must get some inexpensive temp measuring system so you can monitor your homemade air systems for hot air leaks.
