matzinm2 »
https://forums.nicoclub.com/matzinm2-u89907.html
Sat Jun 06, 2009 7:20 pm
for sure, the needle kit is from import intelligence, it's 70 bucks and not really as green as I wanted them to be, but worth it. And the instructions for those come with the kit, VERY tedious; lemme tell you. The blue LEDs in my gauges you mean? Those are simple, your dash comes out wit ha few screws taken out, then unscrew and unplug your cluster and pull it out; behind your cluster there are six brown... um, screw-plug type things that come out with a half turn to the left. Those hold your bulbs, simply put the new LED's (they are 197A wedge bulbs, just pull out the old ones and slide the new ones in) in and screw the little plug-dealys back in. Plug your cluster back in and put your dash back together, your bulbs will work just like the older ones, but not as crappy. I must warn you, if you have the orange paint on your stock needles- orange+blue=opaque, so the needles look quite crappy, what I did (for the needle kit later) was scrape the paint off and repainted the needles using white Testors brand model paint.
That is all.
