1st Dyno Results after rebuild!!!
V8slayr
Car: 97 240sx
My setup:T3/T4 50 trim, .63 ex, stage 3 wheel (journal bearing)Peakboost manifold/ ISIS intake manifoldHKS 264 step 1 cams/ Peak performance valve springsDwerks 740ccEnthalpy ECUCP 87mm 9.0:1 pistons, stock rods/OE bearings/ARP rodbolts
Dyno done on local dynojet
394rwhp / 300rwtq @ 18 psi on 93 octane
Shut it down at 7300 rpm, limiter is set at 8,000, would have seen over 400 if I would have not pussied out.
Emperor_Tha
Your car is fast.
Where did u get the 50trim turbo?
S14toRPS13
Nice numbers. You got any dyno sheets. I want to see the power band.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
Very impressive. Did you feel like the .63 housing was starting to choke out past 7Krpm? I just bought a GT30R (without a housing) and want the .63 ar for spool but don't want it to be to restrictive for 430-440whp. Post your dyno plot when you get a chance. Here is mine with the Hoslet HX35 with a log mani, 2.5" DP, and basically everything else the same except JWT rom tune. I was at 23-24psi but the difference maker was the cheap log mani and 2.5" DP if I had to guess. Tubular mani and 3" DP and I could hit those numbers with 4-5 less psi.
V8slayr
Car: 97 240sx
I got the turbo from turboelements.com about 10 months ago.I do not think the .63 housing is restrictive at all. My graph was still climbing when i shut it down, and on the street the car keeps laying on power the higher you rev it, it feels like it would pull to 9k if I wanted it to. I'm also running a 2.5 in DP and am looking forward to changing it to 3". Down the road when i get a little more comfortable w/ the motor I plan to dyno around 22 psi on race gas, and hope it makes between 420-450.
I do have the graph, but I'm not too good w/ computers and don't have the faintest clue how to post it.
I'm kinda wondering why my torque number is so low tho, Kentucky your setup is close to the same except the ex. mani and you made 40 more ft-lbs. than me??
V8slayr
Car: 97 240sx
You know what tho, my boost creeps like hell and at 5-6k where it made max torque the boost was only 15-16 psi. I'm running a 1 bar spring and no boost controller and it rises to 17-18 psi and holds steady. So anyway, if you look at it that way that torque number is really for 15 ish PSI, compared to the the HP number at a full 18 psi.
kings_club
Car: 1993 silvia k's , 2000 Audi A4 1.8TQ
hey how much boost can i throw at a stock motor?i have a gt28rs on my silvia, and i want to get it tuned.
a buddy told me all i need is a z32maf and injectors to make like a solid 300 wheel.is this true?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
You would need a tune to control the new injectors and maf also
kentuckyslider
Y
V8slayr wrote:You know what tho, my boost creeps like hell and at 5-6k where it made max torque the boost was only 15-16 psi. I'm running a 1 bar spring and no boost controller and it rises to 17-18 psi and holds steady. So anyway, if you look at it that way that torque number is really for 15 ish PSI, compared to the the HP number at a full 18 psi.
I was running 6 more psi. I made about 300tq at 18psi after I installed the ISIS mani. Your peak boost mani is good for 30-40 more whp at the same boost than my log mani. I will have my GT30R on tomorrow and I think it will be much better than the HX35.
V8slayr
Car: 97 240sx
I agree, the GT30 will be much, much more efficient at the boost you want to run and should make hella power. I'm going to the dragstrip tomorrow night on some hoosier autocross slicks, ha ha. They should hook up pretty good though straight up. Hoping I see a 7 sec pass!!!! and trap at least 90 mph!
domiballa
Car: 1993 s13 hatch
so how has that isis manifold worked for ya?
kings_club
well yeah of course i know that. lol
how much am i looking to spend for a solid tune?and anyone know anyplace in the southeast who does tunes?
domiballa
Car: 1993 s13 hatch
kings_club wrote:well yeah of course i know that. lol
just get an enthalpy romtune 550cc injectors and z maf you should see 290-310 whp no prob as long as no leaks and such..
V8slayr
Car: 97 240sx
As far as tuning in the SE close to where we are in AL, the only place I know of w/ reputable tuners is Atlanta. There are a ton of shops over there w/ badass tuners. I am a fan of the Enthalpy ECU though. The way my car runs is like it's completely stock, AFR is perfect under all loads/conditions, and it makes good power. For a mail order tune it works tremendously well.
kings_club
alright thanks alot.how much is the enthalpy guys fee?
timmyk
Car: s14 96 240sx and 89 s13 240sx
nice numbers man, cant wait to get my sr in
