Ajax87 »
https://forums.nicoclub.com/ajax87-u168280.html
Sat Oct 09, 2010 11:31 am
Issue #3: Too many wires coming together at splicing of Black/Red and Blue/Red
Finally, again below figure 5 they mention to connect the blue/red and black/red on the SR harness to the black/red wire on the KA plug pigtail. My harness had two blue/red wires. I looked up the ECU pinouts and one of them was coilpack power, and the other was ignitor power. Logically all these need +12V switched, which is what the black/red on the chassis harness provides, however connecting the extra blue/red would make this a four wire junction, not a 3 wire junction as indicated by the writeup.
Solution to Issue #3
Going against the writeup, I hooked up both of the two SR engine harness blue/reds to the SR engine harness black/red, and then all three of these to the KA chassis plug pigtail black/red. This gave me a four-wire junction, wheras the article implies a three-wire junction. Do not be worried, this is how it should be.
Thats from the continuation of frsport. Theres 2 plugs next to the first injector, thats where the rogue red blue ends. I dont know what ameobassassin is talking about. After my ecu sparked i unhooked that rogue wire, i should have traced it down before i took his word for it. At that junction i have a thick blue red and the black red wires. Is there supposed to be another wire at that junction
