1JZ Swap Z32 Trans
nothinbuddadreamer
Car: 89 240sx
Alright so I'm not sure if this is the best place to put this or if the z32 section would have been better but regardless I was wondering if anyone knew a crossmember kit that will fit a jz to z32 in an s13, I already have the collins bellhousing kit on the way and I'm not sure if the Z32 Trans shares the same crossmember as a CD009 if not I cant find one that will work, worst comes to worst I'll have to modify the jz to cd009 crossmember but this is my last place I figured I'd ask before I did it. Thanks!
PapaSmurf2k3
Site Admin
Yeah trans crossmembers should be fairly easy to fabricate (or modify) if you can't find anything that will work.
If you can't find it at the junk yard or on ebay for a reasonable price, I'd probably just go straight to the fabrication stage.
