1jz s13 wiring question...
otaku64
Car: rps13
hello, we have a non-traction control, non-vvti 1jz-gte from a jza70 supra in an s13. used whatever translated fsm's and references found online. also, we've eliminated all unnecessary luxuries (full-race setup).
here is where we are:
we have the wiring connected according to the fsm diagrams, using the stock 1jz circuit opening relay and fuel pump relay. the circuit opening relay turns the fuel pump when the starter is engaged, but i'm not sure if the ecu is getting an 'on' signal to start the motor. i used a test probe to check negative power to the injectors from the ecu and it doesn't seem like it is getting a signal. is there something you could direct us towards from this information that is missing/wrong with the wiring. perhaps a separate 'on' signal for the ecu? we are looking for another ecu locally now that we could test, but any ideas in case the ecu is good?
thanks!
Modified by otaku64 at 6:07 AM 8/19/2008
robertftw
Car: 89 hatch
Are you sure it is from a supra and not a soaror? The soaror uses a seperate computer to control the fuel pump. what's the code on the ecu?
otaku64
Car: rps13
hi, the ecu codes:
89661-14480
26p 16p 12p 22p
thanks!
- sal
