1jz + 240sx s13
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
vroooom
Car: 1990 240sx
alright so i got this swap im pickin up...
Complete Head / Complete Block / Intake Manifold / Exhaust Manifold / Injectors / Throttle Body / Power Steering Pump / Sensors / Fuel Rail / Alternater / Distributor / A/C Compressor / Turbo Charger / Automatic ECU/ECM (getting manual) / Automatic RWD Transmission (getting manual)
so i still need the mounts, axles, clutch assembly/peddle assembly, manual trans components..
this is my first car that im building so im not sure what else i would need.. if anyone can help me out id really appriciate it.
Thanks.
vroooom
Car: 1990 240sx
bump...
RCA
Um sorry to tell you but forums only work when you have exhausted all your options. You need to search then ask questions
This question has been answered PLENTY of times
www.2jzswap.com wrote:http://www.2jzswap.com/vbullet...=2397
2JZ-GTE Motorset240SX/2JZ Swap KitIntercooler KitExtended Shifter KitClutch Line KitThrottle Cable BracketDown Pipe AdapterMisc. HosesRadiatorTrans Oil Serpentine belt*OEM Toyota 1JZ Bellhousing - *(Unless you use the R154 from the Toyota Soarer or Toyota ChaserOEM Toyota 1JZ FlywheelPulley Kit*Pilot Bearing - *(Unless it allready comes in your clutch kit) Wireing Harness Service Speedometer 8K Magnetic Pick-UpSpeedometer Signal Interface Tachometer Signal Interface 7MGTE Clutch & Pressure PlateGreddy Oil Filter Relocation Kit OEM Toyota Oil FilterNGK Iridium Plugs OEM Toyota Water Pump OEM Toyota Timing Belt Flywheel BoltsR-154 Transmission*Exhaust- *(Because your not going to use your stock 240sx exhaust)Battery relocationMKIII Slave CylinderDownpipeTwin Fal FansWalbro 255 LPH Fuel Pump *Misc. Other Parts, Just in case Funds- *(This could be any number)
Oh and by the way it took me longer to write this then it took to find that list.
Next time try to And if you still want a "Mopar eater" then try an LS1 swap
DRIFTING.com
the 2jz s14 swap shares similar steps
2jz swap dvd pagehttp://store.driftingshop.com/2jzs14swdvdp.html
Return to “Hybrids”
