1G fpr on a CA18DET
fabio240
Car: S13 with ca18det
Ok being that my older brother only does dsm cars and I have alot of his extra parts sitting around... I was wondering can I use a 1g fpr on a ca18det because as many high hp dsms I have seen I havent really heard too much of a problem from the fpr. So as a cheap solution I want to use the fpr from a 1g on my ca... yeah the 1g is bigger but I was planning on getting the fuel rail tapped a little bit larger to fit the fpr in there. I was just curious if anyone knows if this will work I believe that both of the motors run off of the same fuel pressure so I dont see why this wont work.
boost_boy
There's nothing wrong with the stock CA fpr which is just as good. The stock regulator do it's job in excess of 400whp applications. Hope this helps ;) .
float_6969
I suppose you could, but why?
fabio240
Ive just always been under the impression that the stock one gets over run by a walbro fuel pump even tho Im going to be using one from a rx7 fd which is a 210... I just wanted something thats going to keep steady pressure.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
im sure the stock CA regulator will hold pressure just fine at the power levels Dee said. The walbro definitely overruns the stock regulator causing a rich condition. The pressure is raised but still solid.
float_6969
It only does it at idle/low load.
