19s on a s13
iandrew89
Car: '89 Nissan 240sx Redtop SR
'94 Infiniti J30 Stock
'91 Infiniti Q45
Edited to make it easier to understand. Any suggestions are welcome.
-89 Nissan 240sx-5 Lug Swap all around-Konig Afterburner 19x9.5 +25 offset-Tire size unknown-Stance GR+ coilovers or any other suggestions welcome-Roll and Pull fine-No camber-Z32 Calipers and Rotors
Modified by iandrew89 at 2:18 PM 8/6/2009
AZ89two4Tsx
You will need some skinny a** tires. Probably something crazy like a 245/40 idk.
But if you don't want to run any camber, you will definitely need a roll and pull on your fenders.
iandrew89
'91 Infiniti Q45
thanks man also by chance does any know if z32 brakes and rotors will clear that.
iandrew89
'91 Infiniti Q45
Edited to make it easier to understand check OP. Thanks again.
adrianfromthecastle
Car: 1992 Nissan 240sx
iandrew89 wrote:thanks man also by chance does any know if z32 brakes and rotors will clear that.
brake clearance can't be determined by wheel size, because it all depends on the design of the spokes, and its different for all wheels. Hell, Ive seen some certain OEM s13 wheels clear z brakes, and some high disk 18's not clear.
