19in rims offset?
gr8with8s
im looking to put rims on my g35 04 19inch? brembo brakes....does anyone know the offset size?
JeromeS13
Car: 2008 Subaru Impreza STI
Depending on what widths you go with, you want to stay around the low 20s in the offset.
-Jerome
Hookm36
Car: 2004 G35 coupe
does having different sizes matter ? would the offset be the same on the same rim, but a 19X8.5 and a 19x10 ? and what bolt pattern is on the 2004 G35 coupe ?
JeromeS13
The offsets are usually different for different rim widths. Bolt pattern is 5x114.3
-Jerome
C-Kwik
A wheel's offset is measured from the centerline of a wheel. The wider a wheel is, the further the centerline will be from the face of a wheel. If the offset remains the same, when you choose a wider wheel, it will be further out of the wheelwell. It is imperative that you consider the wheel width in any discussion or choice of offset.
