txg37x »
https://forums.nicoclub.com/txg37x-u225833.html
Tue Oct 15, 2013 10:13 pm
The QX4 started overheating. I checked the coolant and it was brown and pasty rust. I've had this problem on another car and got hosed by the mechanic, so I decided to try and take care of it myself. I flushed the system and things were great for a few days. Then the radiator started leaking, which I hadn't seen it do before. First it leaked from the bottom of the radiator, stopped for a few days and then leaked again from the top. I assume it started leaking because the system was now clear of gunk, so fluid was able to leak out. Because of this, I replaced the radiator and things were perfect for about two weeks. Now, yesterday, I've noticed a massive leak from right around the drive pulley. I assume this is the waterpump since it is located just above and to the right...?
Why would the waterpump just now start leaking? Same assumed problem, free of gunk, so now able to leak?
I try to save $ and do things myself, but from what I've seen, it looks like a tough job to replace the waterpump, and if I do replace the waterpump, I should replace the drive belt and a series of other things? Does this sound right? If I take it to a shop, what should I expect them to suggest and most importantly charge?
