yeldogt »
https://forums.nicoclub.com/yeldogt-u177666.html
Sat Jan 14, 2017 10:56 am
First -- no fluid will work in all asian vehicles throughout that range. Toyota changed fluid .. so did Nissan. The OE fluid was if I'm remembering correctly "green" -- BUT ... being green does not = other green coolants. It's just color. Honda was always specialized.
I have no idea what "orange" coolant .. my Jaguars have orange .. but it's completely different vs GM's orange. You can't go by color. Manufacturers pick coolant based on engines components and seals -- plus expected life. Cars with Iron blocks use different coolant vs aluminum etc. Typically, the asian manufacturers use no silicates.
Sometimes the transfer rail (forget what Nissan calls it) in the back of the engine can leak -- how much is it leaking? The transfer pipe requires a lot of labor to replace. I used to get a tiny drop when we had large temp swings bellow freezing on one of mine -- it never amounted to anything. It would occasionally drop a bit more -- I could never find it .. it was in the front passenger side of the engine and would drip on the ground. The engine has many hose clamps -- need to make sure they are all tight .. don't over do them.
If I was going through all the trouble to flush out the orange -- I would spend the $10 more for the proper OE fluid and distilled water. Especially, if I as going to keep the car. When I bought mine back in 11 -- I had all the fluids changed using all OE except the front and rear differentials -- I could not get the grease from either Nissan dealer -- so I used M1 in the proper weight.
