ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Nov 11, 2011 5:15 am
Engine gets hot radiator gets hot as well as coolant.
Your cabin temperature for heat takes what you allow through the heat control.
Hot engine, variable cabin room temp as you modulate the required temperature.
If your engine is too hot or too cold the temp gauge will indicate
The cabin temp needs the engine temp but the heat exchanger in the cabin can only get heat from the engine.
As Chuck has said, if engine heat problems so cabin heat problems.
Where to look.
Feel the input line of the cabin heat exchanger, feel the output lines. If both are hot the same temperature, the exchanger is likely OK, but if in is hot and out is not a problem if heat is demanded.
Check the air flow controls, vent to feet to windows, as you move the control does major air circulation move, try it with cold air, then try with heated air at high flow.
If no heat the valve or the controls that regulate cabin temp is faulty.
Verify controls, verify heat no heat.
With answers return with your results
Do not disassemble anything, but do your diagnostics first.
A vent or primary heat control is likely but if you have never changed the coolant that complete system could be now complaining. By the way flushing the system with soft, distilled water is a total waste of money because as a DIY you do not have the pumps nor the quantity of distilled water. Use a garden hose, flush out while checking for blockages, crud etc, then install only distilled water test your rad heater and run at temperature for a 1/2 hour, let cool dump everything then install new anti freeze at a 50/50 with distilled water and be sure to use long life, stuff, aluminum compatible and no silicates .
If you can test the rad while at temp with an IR gauge all the better, looking for hot and cooler spots on the complete radiator surface, then spot check the cabin heat exchanger.
All this will keep you clean and clear for 5 years, but if neglected the rad is possibly plugged and the cabin heat exchanger could be also. If that is the case a chemical wash is needed.
