The first thing I'd check is the fuel pressure regulator. That's pretty classic symptoms of a leaky one.brynderwen wrote: ↑Mon Apr 04, 2022 3:15 pm1. I have 100K on my 1999 QX4 and started to get a miss fire after car had already been driven and restarted warm. So I knew it was time to change, plugs, wires, and distributor cap. Thanks to this forum, I was able to get #6 plug out with the short tool and not the long tool. It does run a lot quieter but I am still having this miss fire issue for about the first mile after restarting from a warm engine. Cold start no problem. When I ordered the distributor cap, it was vague as to whether it included the head rotor. Of course, it was not included. I ordered one today and perhaps that is the issue. Any idea?
The SEC isn't hard to change and the fobs just need to be reprogrammed afterward, but finding one may be a whole different matter. My understanding is that they've been discontinued pretty much forever. If the relays are getting balky, you may need to find someone to recondition it.brynderwen wrote: ↑Mon Apr 04, 2022 3:15 pm2. I'm also wondering how hard it would be to replace the keyless entry security door module under the dash way up there back behind the steering wheel area. It slowly started to not work anymore. I replaced FOB batteries and I had the extra one that was never used before and put a battery in it, to no avail. I also did the key FOB reset of the ignition sequence and that didn't help either. Anyone done it before?
Rough running and/or hard starting after a warm soak are classic symptoms for a pressure regulator with a leaky diaphragm. What happens is that residual fuel pressure after shutdown forces fuel through the leak into the vacuum side of the regulator, then it gets sucked straight into the manifold through the vacuum hose when you restart. The rich condition doesn't bother the engine when cold, but once it warms up and wants a leaner mixture, the leak floods it and it runs badly till the extra fuel burns off.brynderwen wrote: ↑Mon Apr 04, 2022 10:20 pmOh boy, A fuel pressure regulator? How do I go about doing that? Do you think I can do it? It feels like it is miss firing after I start it from already been driven 5 miles and within leaving a parking lot or so, it will run smooth again. Same symptom, you think?
I looked on eBay using the p/n's from InfinitiPartsDeal and didn't see any. The problem with a used one is, eventually they'll all develop the same issues with worn relay contacts causing intermittent misbehavior. So you might just be replacing one intermittent headache with a different one. I don't recall them being all that hard to replace, I think you just needed to loosen the lower dash panel and maybe the fusebox.brynderwen wrote: ↑Mon Apr 04, 2022 10:20 pmI've seen a few, for sale, security modules out of wrecked vehicles on ebay. I just can't figure out how in the heck I can get that unit out of there. It is way up in there, lodged in. Not sure what to take apart to get to it..........
It’s in a pretty tight spot. To get a Phillips driver on there and exert enough force to loosen the screws and then remove the hose which is on there pretty tight if removing the first time might be extremely difficult.brynderwen wrote: ↑Tue Apr 05, 2022 5:07 pmThanks guys. Oh man, I tried to look for it this morning and I can't seem to find it. Climbed up like a monkey and looked down near #6. I guess if I use a mirror I could see it. I also have a PO325 code, Knock sensor which I already knew about. Also a PO304 #4 misfire, which I believe was one of the wires I replaced last week, but forgot to clear the computer codes.
Has anyone here tried replacing the FPR without removing the intake manifold?
Would it be okay to drive the Infiniti 1,200 miles as I will have to drive that far for a round trip for Easter, next week.
I picked up the new rotor head today and will install once cooled down.
Great to have such great feedback. Thank you
So you've verified that you have a bad FPR? If so, you're probably not going to be able to replace it without removing the intake; and yes, you will need to replace the intake gasket. Here's a link to one of the best descriptions of how to remove the upper intake on the VG33e engine that's in your car. Even though this video applies to the Xterra, the engine is the same and the issues you'll have to contend with are identical:brynderwen wrote: ↑Tue Apr 05, 2022 9:58 pmThanks again for your input guys. When I removed the distributor cap and replaced the new rotor head, I could see the intake manifold better. It looks like it is attached down the middle and there are a few other bolts holding lines up here and there a few hoses to undo and I might be able to flop it over to the left side to get to the FPR. Does that seem feasible? And I agree, I should replace both valve cover gaskets while in there. $142 for the FPR and a few bucks for the o-ring. Would I have to replace the manifold gasket? It doesn't get any oil on it, usually, and it looks clean. I would need a 6mm allen socket to remove manifold. Any ideas?
Your information is very helpful and understandable.
You can pull the small vacuum hose at the back of the intake plenum and see if gas is in there after a few minutes of shutting down the engine. Pretty easy to do.brynderwen wrote: ↑Wed Apr 06, 2022 11:26 pmThanks MisterH,
No I have not confirmed it is the FPR. Not sure how to actually diagnose if it is bad. Watching that video looks like the coolant hoses in the back are a pain in the you know what.
