1999 QX4 engine oil, synthetic or regular 5W-30?
akers912
Car: 1999 Infiniti QX4
I daily drive a 1999 QX4 with almost 163,000 miles and i plan on doing an oil change very soon. I just got a purolator BOSS oil filter and i bought five quarts of Pennzoil platinum SAE 5W-30 full synthetic oil. Should I use this synthetic oil or should i use conventional oil? I've seen different threads saying yes and no so its really hard to decide!
akers912
My QX4 has 163,000 miles on it and i plan on doing an oil change soon. I have no idea what kind of oil has been previously put in it. should i use synthetic or regular 5W-30?
ArmedAviator
Car: 2012 Infiniti M37x
If you want to increase your oil change interval (7-10k), go with "synthetic". If you want to keep a lower (3-7k) OCI, go with regular.
ArmedAviator
Please see my post in your other thread.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Threads merged. akers912, please don't create multiple threads for the same topic.
UpUp_Away
Car: 1998 Infiniti Qx4
Just use synthetic and don't look back. Synthetics don't create leaks, they just clean the sludge and buildup in your engine really well. The "leaks" stories come from the sludge clogging up the leaks that are already there, and switching to synthetic cleans up the sludge, which would unclog it (which is a problem you should fix anyway and not put off by using low grade oil).
If you're just switching to synthetic after a lifetime of conventional, I'd do my next oil change a bit sooner, say, 5k miles, because there is going to be a surge of sludge that is going to be eaten up by the oil and filter, after which you can keep your 7.5-10k oil change interval.
barnaclebob
Car: 2001 Pathfinder LE
2011 Altima SR
Been using synthetic for only about 15k miles now with no issues, 5k change interval, 150k total.
