1999 Q45t with oil leak
mandell
Car: 1999 infiniti Q45t
I have an oil leak at the Filter, changing the filter does not do the trick. is there some type of gasket i can replace for this. I have looked for Adaptor gaskets of some kind but have had no luck. Any suggestions?
Q451990
There are a couple of threads in this forum about similar leaks on the QX4 and I30/35 I believe.... please check them out and let us know if you have a similar design.
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Which filter are you using? Are you dropping the engine tray and replacing from underneath?
