1999 q45t factory wheel size?
GM991
Car: 1999 Q45
was wondering what the factory size of my 17 inch wheels are?I think they are 17x 7.5??
Looking for an infiniti/nissan OEM direct replacement size wise.Don't have the money to go out and buy new tires right now.Whats out there that might be the same size? G35, M35/45???
thanksGM991
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Not much with the exact same offset. Did you take your car to the dealer or register it with Infiniti Customer Service? There is a TSB on recall of those wheels for a certain series of VIN. If yours falls into that spread, Infiniti will repalce your wheels.
The TSB has been published here several times, so try a search.
Your wheels are 17x7.5. I think offset is 35mm, but check your owner's manual or FSM. About an inch too narrow for 255/45-17, in which size fewer good tires for the Q45 are made. This was considered the optimal upgrade about 3 years ago.
GM991
Car: 1999 Q45
ThanksI have not registered it with Infiniti Customer Service. How do I do that?Can I just call a dealer and find out if the VIN falls into that recall?Is there a time limit as to when they would do it? It is a 1999.
thanksGM991
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
No, it is a constant recall. Some of the hubs cracked. Try to find the TSB as it will be most likely quicker and more accurate than the dealer. Just call Infiniti Customer Service and register as the owner. Number in your owner's manual, or probably on their website.
Your profile doesn't include your location, so I don't know where you are and which dealer may service you.
GM991
Car: 1999 Q45
well thanks for the infobut 1999 Q45t's do not fall into the recall.Infiniti looked it up and I looked on this web site and 99's were not included.
http://auto.consumerguide.com/...ility/
thanksGM991
Rex
Car: None
The recall info has been posted and I would trust the posted (copy/paste from Infiniti info) moreso that what's on the consumer guide web site.
As for wheels, there are some F50 17x7.5 wheels, pretty sure they're 6 spoke design.
GM991
Car: 1999 Q45
they
Rex wrote:The recall info has been posted and I would trust the posted (copy/paste from Infiniti info) moreso that what's on the consumer guide web site.
the only reason I thought the 99's were not in the recall is because the dealer and consummer guide said the same thing.I did a search out here and didn't come back with anything on this recall/TMB
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
ITB03-024 April 23, 2003VOLUNTARY RECALL CAMPAIGN2000-01 Q45 ALLOY WHEELCAMPAIGN I.D. # / NHTSA #: R3006 / 03V-098APPLIED VEHICLE: 2000-01 Q45 (FY33) – (Touring/Anniversary model with 17” alloy wheels ONLY)APPLIED VINS: Vehicles built between:JNKBY31A*1M100002-101879JNKBY31A*YM300015-302786JNKBY31A*YM701255-701280
So the 1999 model is not covered. Sorry about that.
Rex
Car: None
Thanks Brian for finding that ... it does appear the 1999 is not included, but I wonder what your dealer would say? Would they inlcude you to be safe or would they not have any idea what you're talking about. I think it's worth mentioning during the next oil change by the dealership.
GM991
Car: 1999 Q45
maxnix wrote:ITB03-024 April 23, 2003VOLUNTARY RECALL CAMPAIGN2000-01 Q45 ALLOY WHEELCAMPAIGN I.D. # / NHTSA #: R3006 / 03V-098APPLIED VEHICLE: 2000-01 Q45 (FY33) – (Touring/Anniversary model with 17” alloy wheels ONLY)APPLIED VINS: Vehicles built between:JNKBY31A*1M100002-101879JNKBY31A*YM300015-302786JNKBY31A*YM701255-701280
Thanks for the info.....
as far as the dealer including me........ ...is what they said...No go they said like Brian pointed out 99's are not coverd....bummer..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
There was an alternator recall, but that was only for 1997 (I hope I remember this one correctly).
Why one must read the ton of TSB on the FY33 and pick what's applicable to their vehicle.
Dealer ain't going to do squat for the wheels unless you detect a manufacturing defect yourself. Who's to say they weren't on a 2000 before you got it? Surprised the TSB does cite a wheel code as they are easily remountable on a different vehicle.
Rex
Car: None
maxnix wrote:... Dealer ain't going to do squat for the wheels unless you detect a manufacturing defect yourself. Who's to say they weren't on a 2000 before you got it? Surprised the TSB does cite a wheel code as they are easily remountable on a different vehicle.
I guess that just bugs me a little. I understand if they aren't covered they don't ahve to do anything, but they should want you to think they'd do everything in their power to get Infiniti corp to take care of a customer.
True the wheels could be off a "covered car", but (sadly) again, I've heard stories where they'd only cover them if on a correctly matching VIN (to the recall) car .
Sometimes I think they forget the Total Ownership Experience
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
And they are warranteeing the wheel, carte blanche.
I thought someone here got them replaced when they were on a G50?
Modified by maxnix at 3:18 PM 8/3/2006
