1999 q45 Vapor Canister Purge Solenoid Valve LOCATION?
Replicaracks
Car: 1999 q45
I have a check engine light and its been diagnosed as the Vapor Canister Purge Solenoid Valve. They told me its under the intake is this correct? The car a over 200k miles and I don't want to spend a ton of money on repairs. Is there anyway around this? Any info is appreciated, seems all the valve has is 2 vacuum lines and a connector.If it is under the intake would it be possible relocate it to a different place without removing the intake? Thanks
Q451990
:welcome: to NICO!
Check out your car's factory service manual at http://www.infinitiservicemanual.com for a location. I don't see why you couldn't relocate it if you can somehow unplug the electrical connector to the valve. Sometimes all that's wrong is a dirty electrical connector.
