bullittandy wrote:Is the converter electronic, mechanical?
The lockup clutch is mechanical, but hydraulically actuated by electronics. So the problem could be any of the 3. FSM recommends checking the closed throttle position sensor. I'd start with that and the lockup clutch solenoid.
Skibane wrote:Almost sounds like it's not unlocking as soon as it should. If it didn't unlock at all, the engine would stall.
That's kind of my line of thought as well. I wonder if maybe it's just not releasing all the way...meaning maybe the line pressure isn't being fully released so it's remaining partially engaged. How does the car behave while stopped? Does the engine still struggle or does it idle okay once you get stopped or below a certain speed? Usually torque converters unlock below about 45mph, so if it does feel like it eventually unlocks, that at least tells us a little something. The converter should also NEVER lock up at all at any speed in 1st or 2nd gear, which goes along with Skibane's post.
