Welcome to our club.
You did not mention the appearance or condition of the fluid. Ever been replaced?
Neither did you mention the maintenance history for the front suspension. How are the tension rod bushings? How old are the shocks?
I think you need to plan on replacing the front accessory drive belts and pulleys. All the belts at once to avoid repeat labor, have all pulleys on hand because you don't which are bad until you inspect them with the belts disengaged.
http://www.infinitipartsusa.com is your friend.
Modified by maxnix at 10:09 AM 11/30/2006
