1999 q45 (non-T) Suspension
Reventional
Car: 1999 Infiniti q45
Front Struts for a 1999 Q45 non touring.
I have the money for my suspension parts, mainly concerned with the front. I dont know the condition of all the parts in the assembly so i need to know what else should be replaced other then just the strut assembly.
Thank you!
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
So you're doing the stock struts inserts? Depending on miles your springs could be worn out too. How long you plan to drive this car? If your setting up for the long haul I would replace the springs too. While you are there do the tension rod bushings and all the rubber parts in the sway bars. These are worn out too for sure.
