Go here:
http://www.nicoclub.com/FSM/Q4...c.pdf Then go to ENGINE AND EMISSION CONTROL OVERALL SYSTEM then ENGINE CONTROL COMPONENTS PARTS LOCATION or VACUUM HOSE DRAWING.
That will show you where the EGR is then from there if you are a DIYer you can see how to remove it.
But these cars were meant to see the dealer about the smallest things so if you have your doubts seek a pro or read the FSM and go from there.
And you might also want to use brake parts cleaner on the valve its self and a pipe cleaner for the tube that goes to it.
I could have posted some links but I am tire buy you can always search.
Modified by ppastos at 11:04 PM 10/18/2008
