I have a 1999 nissan quest v6 3.3L 140k miles automatic. I was driving on the highway and the car started to miss a little and then it died out when I got to the side of the road. I pulled over and checked everything out and everything looked good so I started driving again and I got just a little bit down the road and it died out again. Now this time it wouldn't start. So i got the car towed to my house. The next day I started the car and let it idle and it turned off after 10 minutes. I tried the next day and it also tuned off after idling for 10 minutes.
The only issues I notice with the car is a squeaky belt and I know of the stabilizer belts are bad.
The only things I had to do in the past year is change the alternator.
I do have a check engine light and got the following codes.
P0110 Intake Air Temperature SensorP0325 Knock SensorP0340 Camshaft Position SensorP0731 Gear 1 Incorrect RatioP1336 Cranshaft Position Sensor
Any ideas whats going on or what to check for?
Modified by umoms at 10:50 PM 2/9/2009
