Main things:
The car has a VG30E 3.0 liter or VG33E 3.3 liter V6. Both use timing belts which need to be replaced every 60,000 miles.
Try to stick to NGK spark plugs. The VG likes them best and will generally give you less hassle with them.
For a LOT more info, you can get the factory service manual for the car here:
http://www.nicoclub.com/FSM/quest/1999_Quest/
That should have all the info you'll need.
