1999 Nissan Pathfinder Used Aftermarket Wheels
AMOCO
Car: 1999 Nissan Pathfinder
I want to go to a 16" wheel since I have a set of Firestone Destination A/T's 235/70R 16's that are almost new.
These are the wheels here that I am looking at,And the wheels were on a 2003 GMC Yukon.
https://cosprings.craigslist.org/pts/d/ ... 54469.html
Here's where I get confused.I checked at https://www.wheel-size.com/
The Offset is what I am concerned about.I used Wheel Offset Calculator,But I don't understand the results.
Current Wheel Specs
Width 7 inches
Offset 30mm
New Wheel Specs
Width 7 inches
Offset 31mm
Results;
Inner Clearance:
1mm LESS
(the inside of the wheel to the strut housing)
Outer Position:
RETRACT by 1mm
(position of the outside edge of the wheel)
The quick answer: 1mm makes no difference. The wheels you looked at are fine.
Offset is where the mounting pad of the wheel sits relative to the outer lip of the rim. Think of a FWD car as having high + offset, and an old lowrider as having negative offset.
AMOCO
@ AZhitman,Thank you very much for your response and They won't stick out the wheel well?
Nope. 1mm more "sunken." 1mm is the thickness of a dime.
