P0131 is a code for the
passenger's side front (upstream) oxygen sensor. P0151 is a code for the
driver's side front (upstream) oxygen sensor. P0160 is a code for the
driver's side rear (downstream) oxygen sensor. P1105 is indeed a code for the manifold absolute pressure switch solenoid valve; my previous reply was incorrect.
Did you replace the MAP switch solenoid valve? If so, what brand of part did you use? What brand of oxygen sensor did you replace the passenger's side upstream sensor with?
I feel that there is a technical service bulletin related to these oxygen sensor codes, but unfortunately my Chilton's online link died a few months ago so I cannot look up TSBs unfortunately. All of your codes have equal priority.
Try loosening and retightening these ground screws:
