1999 Nissan Maxima Trouble code questions
nlacke001
Car: 1999 3.0 v6 nissan maxima
Hello, I have these codes any insight will be greatly appreciated.P1320-open or short-cam sensor
P0159-open shortsee above
P0158-open short-see above-High fuel pressure-possible injector leaking
This is what one of the jerk offs from auto zone wrote down. Its a 99 Nissan Maxima 3.0 v6.
I'm thinkingchanging the fuel pump and cam sensor, any ideas? Thanks
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Please refer to the Maxima/I30?I35 FAQ sticky in this forum regarding DTC codes. For the 4th gen Maxima, P0158 (Max Voltage Monitoring) and P0159 (Response Monitoring) refer to problem with the Rear Heated O2 Sensor, Bank 2. You have to replace this sensor. If not, the catalytic converter may fail and that is very expensive to replace.
DTC Code P1320 refers to problem with the Ignition Signal Primary (Ignition Coil) - ignition circuit harness or connector; power transistor in ignition coil; condenser; or crankshaft position sensor.
Please download a copy of FSM (Factory Service Manual) and go to EC (Engine Control System) chapter. It will give you instructions on how to do your own diagnostics, interpret the DTC codes and isolate the problem.
