drshottest718 »
https://forums.nicoclub.com/drshottest718-u138925.html
Wed Jul 22, 2009 11:23 am
The problem began about a month ago. I went on vacation shortly after it occured and just got back to trying to fix it.
I drove the car all morning, parked it up and around 5pm when i went to turn it on, it turned on and died down about 1 second afterwards. I tried to turn it back on and about 3 times later after doing the same thing, it just cranks endlessly. it does not turn over.
I have replaced:
spark plugsFuel pump
I have checked:
spark in all injectorsfuel filter fuel pump is priming battery is good.MAF is clean and functioning
NO CELS
I was told it might be the main fuel relay and i checked that as well today. I replaced it with a similar relay for the horn, and it still would not turn on.
When i was troubleshooting a couple weeks back i purchased fuel additive spray and i sprayed it into the intake mani and when i did so the car would turn on, as long as the spray was going into the mani. This leads me to believe that maybe the motor isnt getting enough fuel PRESSURE. Although i have never heard of a FPR going bad. The motor is definitely getting fuel because i hear the pump prime and i also checked the fuel line going into the filter and when i removed it, tons of fuel came out.
Any insight would be greatly appreciated.
Thanks in advance guys.
horrible update.
After towing the car via rope and tow hook to a nearby shop, the mechanic asks me to try to turn it on.
I hear a slight clicking/knocking noise.
I get out of the car and ask my brother to crank it so i can hear where its coming from. Sure enough there is a noise coming from the timing chain cover/housing. At that point i'm all like WTF?!
He told me he'd check what the noise is...then he starts trying to tell me if its not 'worth' fixing he can sell and install a replacement motor he has for 1k$
I dont know HOW THE f*** that noise came to be because i've never heard it before. The timing chain wouldnt have fallen off the teeth while the car was parked in my lot.
Modified by drshottest718 at 1:59 PM 7/23/2009
