1999Max »
https://forums.nicoclub.com/1999max-u126987.html
Mon Feb 16, 2009 2:20 pm
I drive a 99 maxima 5-speed and during normal driving it drives fine. If I try to pass someone or just under a heavy load it hesitates really bad as if all power has been cut in half. I've been researching and come up with a bad coil pack but I don't have a code? I did the check it yourself method with unplugging one at a time to see if your engine doesn't react with one of them (the bad one) but my engine reacts with all of them as if none are bad.
Also if I let me car sit for a lil while and try to crank it up, it will start then die by itself. If I try to crank it up again it starts right up as if nothing had happended. Could that be resulting from the problem above or something simple like a loose battery connection or something like that.
