MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Tue Nov 27, 2007 10:57 pm
Welcome to NICO.
The trim piece that surrounds the shifter is held in place by metal clips on the bottom and two plastic bits that hook under the center cascade trim (where the radio is). Use a flathead screwdriver wrapped in a rag or something similar to pry the bottom loose then lift and pull out from under the center cascade trim.
There are two screws under that trim piece, and two more screws under snap-covers on the lower rear sides of the center console itself.
After the screws are out, just lift the console up and off.
