1999 Altima Tie Rod Torque Spec
General discussion area for the L30-chassis Altima
RedDragon9
Car: 1999 Nissan Altima
2010 Nissan Frontier
What is the inner and outer Tie Rod Torque Spec for a 1999 Altima? Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Inner rod to rack is 58~72 lbs/ft, outer rod locknut 27~34, outer rod castellated nut 87~139. Values are on page ST-16 in the manual.
https://www.nicoclub.com/service-manual ... 9%2Fst.pdf
RedDragon9
I think the outer rod castellated nut Value is an error, that seems way to high for that.
VStar650CL
Technical Expert
Nope, that's a tapered joint. Needs to be very tight to seat the taper, especially with a new part. With a re-used part you can be a little sloppier and it probably won't matter.
Return to “2nd Generation Altima Sedan (1998-2001)”
