P0720:
Possible causes
- Speed sensor harness or connectors
- Sensor circuit is open or shorted
- Speed sensor
When is the code detected?
Diagnostic trouble code is detected when Transmission Control Module (TCM) does not receive the proper voltage signal from the sensor.
Might not be the sensor itself if the sensor was replaced. Could be the wiring/harness to TCM.
P0325:
Possible causes
- Knock sensor circuit short to ground.
- Knock sensor circuit short to power.
- Knock sensor circuit open.
- Damaged knock sensor.
- Powertrain Control Module (PCM) or Electronic Control Module (ECM)
Possible solution
- Repair or resecure harness or connector
- Replace knock sensor Bank 1 (Bank 1 if applicable)
- Replace PCM/ECM
Factory Service Manual for your car:
http://www.nicoclub.com/FSM/Altima/1999/
ec.pdf page 241 - Knock Sensor.
Although, the sensor may be fine... maybe your motor is knocking slightly and you don't realize it. Put in 91 Octane. See if that code stays off after it's cleared.
