merc68k »
https://forums.nicoclub.com/merc68k-u34529.html
Sat Apr 15, 2006 9:41 am
Hi guys,
I've got a 1999 Altima (100,000 kms) with a miss off idle. If I tap the gas at idle, the revs drop slightly and nothing happens for a split second before the engine responds. I've been trying to figure it out since I got the car almost 2 years ago and I've done the following so far:
I've checked for vacuum leaks and I'm relatively sure there are none.
I put a vacuum gauge on the fuel pressure regulator's vacuum line and it shows 22 inches of vacuum at idle. I did notice that the vacuum is not smooth at idle, it wavers back and forth quickly maybe +/- 1 inch, about 6-8 times a second. Once off idle, this smooths out, which seems a bit strange to me. The idle itself is smooth.
I've checked the fuel pressure, and it's within spec. The regulator behavesas described in the service manual when I disconnect the vacuum line.I tested the MAF sensor and its output voltage rises smoothly with anyincrease in throttle opening.
I tested the TPS and it operates smoothly and is within spec.The coolant temp sensor and intake air temp sensor both are about rightaccording to the service manual.
It has clean plugs, newish rotor, cap, and wires, and is not burning oil orcoolant.
The air filter is relatively clean and the fuel filter is new.
There are no trouble codes stored, and aside from this problem and having aslightly high idle, the car runs smoothly and has good power at all otherrevs... although there is some hesitation at times at very low revs which I assume is likely related to what's causing the idle hesitation.
The problem manifests itself as a drop in revs/stumble when I tap thethrottle off idle. It's most obvious with small abrupt throttle openings,the kind you would use to take off from a stop (it's a manual trans).It's more severe when the car has been started between 5 and 10 minutes ofhaving been shut of and is still warm. With a shorter or longer stop, itdoesn't tend to be any worse than normal.
I tested the O2 sensor as well as I could with the tools I have; my analogmeter's lowest range is 10V, so it's hard to accurately monitor the sensorwith it, and my digital meter I suspect is a bit slow to show the voltagechanges from the sensor. But, with the digtal meter, the voltage seemed tosettle around .2 volts at idle, and would spike up to around .7 if I revvedthe engine. I measured the resistance of pins 1 and 3 (the heater element Isuspect) of the sensor, as per the service manual's instruction, and itreads almost 8 ohms hot, and 4.6 ohms or so at around 5 degrees C.
The service manual says it should fall between 2.3 and 4.3 ohms at 25 deg.C, so I assume the idea is the resistance increases with temperature. Ifthat's the case, then at 25C, I would expect the resistance to be more than4.6 ohms as I recorded at 5 degrees, so that is somewhat suspect.
I tried the diagnostic mode built into the ECU where the CEL blinks on and off as the sensor cycles between rich and lean, and at 2000 RPM it happens about 10 times in 10 seconds, but at idle, it might happen 1-2 times in 10 seconds.
I priced a new sensor at around $100 CDN today from the dealer, so I'm halftempted to install one. If it doesn't fix the problem at least it will benew and might help my fuel economy a little although it isn't poor to beginwith.
Any thoughts/suggestions as to what else I might look at?
