1999 Altima Front Axle and Clutch Replacement -DIY?
General discussion area for the L30-chassis Altima
aznissanaltima
Car: 1999 Altima GXE
Hello,
I'm new to the forum. Searched, but no luck finding the answer.
I just bought a 99 GXE 5 speed. It needs both front axles.
Is this an easy DIY job for an average backyard mechanic?
It also needs a clutch - is that job something I can do without any special tools?
Thanks
Notorious170
Car: 1998 Nissan Altima Bagged *Totalled*
2005 Dodge Magnum R/T Bagged
the axles arent a difficult job as long as you have the right tools.
you can download the field service manual from this site http://www.phatg20.net/modules...id=69 give you an idea of the parts involved
aznissanaltima
Thanks for the link. I'm going to give the axles a shot, not so sure about the clutch tough.
aznissanaltima
I replaced the left front axle last night. It was one of the easier axle replacements I've ever done, no real special tools, although I had to rent a 36mm socket for the axle nut.
Notorious170
no problem on the link. good luck if you decide to do the clutch
00_Altima MD
Car: 2004 Sentra SE-R Spec V
you will not need any special tools to do the clutch. i once did a transmission in the parking lot of my apartment complex when i was in school, however it is not something that i would recommend, but still not that difficult.
aznissanaltima
Wow - now that's encouraging!
I'm concerned about getting the darn thing lifted and lined back up. Is it light enough to do without a transmision jack? Any other words of advice before I get started on it?
Return to “2nd Generation Altima Sedan (1998-2001)”
