Qxxx4 »
https://forums.nicoclub.com/qxxx4-u85589.html
Mon May 25, 2009 11:12 am
you got it right just make sure theres a 4" centre bore and a 3.5"-4" backspacing,the profile will fit perfect its the exact same as mine but your width will give you some rub when turning, my 275's rub in the front when turning to the left at full lock but not the other way, even then its just hitting the plastic in the wheelwell and I never turn that much unless im parking into a tight space
