rdlikes2shop wrote:But the same remote worked after the repair. What else could prevent the Dash flashers not to work ie go into programming mode?
This:
Towncivilian wrote:Have you ensured all of the door switches are undamaged and functional? If one is busted, it will mess up the programming procedure.
Make sure your security light isn't flashing, that all doors are closed and locked, and interior light isn't on. Also make sure the key is going all the way in & out.
I went through this process about 100 times last year trying to program a remote for my new QX4. Turns out the two "working" remotes I bought on ebay didn't work. I took a trip to my local Infiniti dealer and had the parts guy check them. Since it's a quick process to program them, usually they will do it for free if you take them the car & remote.
