1999 1/2 Nissan Pathfinder 2wd engine and transmission swap
nfernandez1997
Car: 1999.5 Nissan Pathfinder
I have a 1999.5 Nissan Pathfinder 2wd that has a slipping transmission, well at 360,000 miles I figure that the engine probably isn't that far behind it. I found a relatively low mile 2000 Xterra 2wd that has been wrecked close to my house. In theory the engine and transmission should be identical to the one in my Pathfinder. Does anyone know what if any modifications I would have to make to the Xterra engine and transmission to make them fit in my Pathfinder? Thanks
heavy hitter
Car: 2001 QX4
if i remember right it bolts right up. the xterra transmission is a much more sturdy transmission as well. this thread is on a auto r50 with a manual xterra swap...but shows it can be done no problem https://www.pirate4x4.com/forum/nissan/ ... -swap.html
