maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Tue Apr 17, 2007 4:55 pm
I would agree with the above post, as far as things to check first.
I am local to you, and wouldn't mind helping you if needed. I don't normally drive 80mph, but I can tell you that I turn right around 2500rpms @ 70mph (97 Maxima, automatic trans). So, it doesn't sound like you are off much. Do you have an automatic, of 5 speed?
You could also have a faulty vehicle speed sensor. With your rpm range compared to the speedometer reading, I would lean in that direction to start.
