Slumpert »
https://forums.nicoclub.com/slumpert-u216156.html
Tue Feb 26, 2013 5:41 am
Maybe check the power wires going to the relay..
I don't mean see if it is 12v, check that there is solid connections all the way to the fusebox, change the fuse, and then follow the cable to the battery.
You might just have a bad supply issue here..
Warning----------- Not for faint of heart------------------------ Something I as a total hack redneck home garage mechanic would do..
Remove the fuel pump relay and ground Terminal 2 or 3 then turn the key on for 2 sec.
Should pop the 15amp fuse #17.. If it doesn't then you know there is a bad connection. It is possible that will complely fried out the weak wire, and while not usually enough to cause any fires, having a fire extinusher handy is recommended as that wire may well indeed be covered in oil and other flamable stuff.
