First time on the forum. I already got some info to help fix my rear wiper, so thanks for that.
I wonder if anybody else has experienced, and I hope, solved this problem...?
My '98 QX4 3.3L (which has an old-style distributor with a single coil inside) starts great when cold (beyond -30 F) and runs great in general. About 5-6 months ago, it started running roughly just for the first two minutes of a hot restart. Typical scenario: Drive 20 minutes to the store; shut off engine; come out after 10 minutes; restart for the drive home. In cases like that, the engine starts immediately, but I need to sit in the parking lot idling for about 120 seconds before I feel the engine smooth out. If I start driving right away (or even just give it gas), my check engine light flashes and you can feel the engine misfiring. The codes are the somewhat vague misfire in cyl 2 (P0302) and sometimes the knock sensor (P0325). I have read that these two codes will appear whenever the engine misfires, for a number of reasons (i.e., the engine detects its own misfire, and the knock sensor senses the rough engine)--and don't necessarily give much help. Here is what I have replaced so far:
- Plugs
Plug wires
Ignition coil
Ignition ignitor
Distributor cap
Distributor rotor
A tech on another site mentioned the evaporative emissions system as being a known issue on the pathfinder from this era:
I have checked the tubing mentioned, and also clamped off, one at a time, each of the vacuum lines under the hood that seem to run to the EGR, EGR control solenoid, and from the evap system in the back of the car into the intake system. None of these changed anything. Also, now that the weather is warmer and I'm driving longer distances, I notice that the misfire condition now comes during regular driving, after the engine is fully warm, and only for a short time span before it clears and runs smoothly again. Again, it is just like clockwork...start the hot engine, let it idle, feel the minor vibration as it misfires, and then feel it smooth out....this is caused by a vacuum leak, a vapor lock issue. this should be flagged as I believe all 1996 and 1997 possible 1998 pathfinders are going to have this problem. a P0302 #2 cylinder misfire w/secondary code of P0325 knock sensor. before replacing injector 2, wires , plugs, etc.. check the vacuum line above rear drivers side tire, small hose from charcoal canister up over the shock to the purge valve.The rubber hose from the canister connects to a metal hose then the metal hose connects back to a rubber hose to the purge valve. The METAL hose corrodes and leaks causing a #2 misfire for a small amount of time when warm started. pass this on few mechanics know of this. you will see the metal corroded.
Does anyone know what the actual algorithm is in the engine management computer, regarding the evap and EGR systems? The above post would imply that the computer says: if engine is fully warm, open vacuum from A to B for 120 seconds after hot startup and then again ever 10 minutes, or something like that. If so, that matches my experience with this...
Thoughts and suggestions for further troubleshooting would be appreciated.
Thanks a lot.
