I'am in dieing need of help, I have a 98 Infiniti qx4 4wheel drive and I have the code issue p0731 but here is the thing, when I try putting it in reverse it doesn't go it almost seem as if its going in park instead
Example: if the car is at a slow roll and I put it in reverse it will lock up instead almost as if u are putting it in park and not reverse.
Another thing that Is happening is that when I put the vehicle in (N) neutral it will be in drive instead also the vehicle will not even roll backwards when in reverse it will not roll in reverse period unless I turn t vehicle of completely while leaving the key to the on position but not to start the vehicle its also sluggish when accelerating from a complete stop it seems like its stuck in second gear also it doesn't even shift while driving just constantly one gear maybe 2nd or 3rd
